Where's the torque??
  • joonsup
    • 776
    So after driving two of my friends' e30 I realized that I don't have the same amount of torque. One of them has LSD and the other one doesnt. However on both cars I can feel it "pull", especially in 2nd gear. Mine on the other hand feels like there's no torque and does not give me that same feeling of "pull". My friends also confirmed that same feeling or "lack of torque" feeling
    A friend of mine suggested a valve adjustement which he did for me this past weekend. The engine is a lot quieter now compared to all the loud ticking noise. However I still don't feel that "torquey" feeling. Any suggestions as what could lead to that or help improve that as far as maintenance wise? Thanks
    I've replaced the spark plugs (not wires/ or cap/rotor), did timing belt/water pump after i got the car (4 months ago). Fuel pressure was fine.
    Someone suggested that the timing belt be off by a tooth? Or timing belt not properly installed? I don't have a timing gun so I can't check that right away. Vacuum leak somewhere? I tried swapping the AFM with my friend's car and that didn't do anything. Any suggestions would be appreciated. Thanks
    btw I have a 1990 325i
  • kishg
    • Sep 2006
    • 2624
    mileage on motor?
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
    • Erick
      Official R3V Drifter
      • 11169
      If the timing belt was off by a tooth, your car would sound like a Subaru and run like REAL crap.
      Vacuum leak doesn't fit, because once you're full throttle you could slice your intake boot in two and it wouldn't matter.
      How many miles on the motor? Does it burn any oil? You sure your buddies don't have a shorter ratio diff?
      ..::Support FullOpp::..
      FullOpp Stickers for sale!
      Feedback Thread
      • ieatpeople
        • Mar 2008
        • 883
        ^this.
        Originally posted by BillBrasky
        That's like Vlad challenging Chip Foose to a car painting contest.
        Originally posted by acolella76
        i'm pretty sure 'Phillis' is short for syphilis
        2007 CVPI, stock and slow
        1994 tercel, 5efhe swap, i/h/e
        1984 t-type, 5.3/th350 swap in progress
        My newest addition:
        Rebecca Arlene, born 4/19/2013
          If you feel a loss of power when at WOT, check to see if the WOT switch in the TPS is operating.
          • joonsup
            • 776
            there is 247K miles on it so far. WOT switch? hmmm ok I will have to check that out.
            One of my friends has the 4.10 LSD? (sorry if i didn't say it right) The other friend has stock differential. I was under the impression that the 89-91 came with the same open differential? no?
            • kishg
              • Sep 2006
              • 2624
              probably needs a rebuild..
              '91 SpecE30 #523
              128290
              • joonsup
                • 776
                could you fill me in as to what that would consist of? thanks
                • SpecM
                  • Oct 2005
                  • 4531
                  five-speed 89-91s came with open 3.73's, with LSD as an option. only auto 325i's and most m3s came with a 4.10, LSD in the M3 and optional in the 325i. But, the diffs are an easy and common updrade on five-speed 325i's
                  replace the cap/rotor, clean out the TB, and check for the operation of the TPS (aka "WOT switch"), and realize that a car with almost a quarter of a million miles on it is probably down on compression a bit
                  ALSO: what kind of plugs are you running?
                  1989 cirrisblau-metallic 325i
                  • joonsup
                    • 776
                    i just switched plugs to some bosche platinum ones. The 3 dollar ones. I understand that the car has a lot of miles but both my friends' e30 have similar miles. Maybe the top end was rebuilt on theres, i dunno. I'll try to check the TPS. I thought the TPS was separate from the WOT switch. What a newb I am.
                    • Red88
                      • Nov 2008
                      • 1161
                      Are you running hot or do you have a rough idle due to the platinum plugs?
                      Have you made a purchase from www.blunttech.com recently?
                      sigpic<< wrecked
                      • mikegar
                        • Aug 2005
                        • 523
                        do your friends have by chance etas? etas swapped with 3.73 gearing ratio or a chip?
                        Originally posted by Ferdinand
                        I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
                        DIVING BOARD DIVISION DIVISION IDIOT
                          • 34839
                          platinum plugs are a no-no on an M20. try NGK BPR5ES instead, gapped to .032
                          • joonsup
                            • 776
                            my idle is good right now and my temp is less than half way
                            One of my friends has 4.10 lsd but no etas. My other friend I keep making fun of him saying that his car as a super eta or what not, but when he bought his car on craigslist the guy said the top end was rebuilt
                            oh crap. Ok I'm going to get new plugs tomorrow. are the ones you listed readily available at the local auto store or do i need to order them? Thanks for the information.
                              • 34839
                              I got BPR6ES (one heat range colder) at napa for $2 a peice over the counter, so they should have them in stock almost everywhere.
                              Bosch plugs are OK but I made the switch and I don't think I'll be going back. :)
