M20 Misfire (Please help....)
  • iamsam
    • Jun 2008
    • 174
    Originally posted by nando
    have you checked grounds? because they can cause issues like this.
    does the check engine light flash at all when it misses?
    have you run a compression test?
    have not delved into checking grounds too much. Can this really cause a misfire like this?
    check engine light does not flash.
    Compression test came back ok.
      • 34844
      Yes, all of the engines sensors and the ECU rely on having a good ground signal.
      there should be two, one from the oil pan to the frame, another on the passenger strut tower. if it's missing, loose or corroded you have a problem.
      • iamsam
        • Jun 2008
        • 174
        these grounds will i check.
        and thank you so much for your help.
        • thereisnoyun
          • Feb 2007
          • 2301
          TPS?
          if all else fails try another set of injectors.
          • iamsam
            • Jun 2008
            • 174
            Originally posted by thereisnoyun
            TPS?
            haven't messed w/ the TPS but from doing some searching it doesn't sound like the TPS would cause this problem. And the injectors we swapped in worked i know because they ran fine in the other M20.
            • structured
              • 954
              Another bump (no homo) because I just had an epiphany. My misfire came shortly after driving my car, which is lowered, through a bumpy ass field. Maybe I knocked that bottom ground out of place. We'll see tomorrow.
              • iamsam
                • Jun 2008
                • 174
                let us know if that was the problem!
                • DTMbimmer07
                  • 1485
                  if you figure out whats wrong with your car let me know, my car is doing the same exact thing, i just blew out the fuel return line today and changed the fuel presure regulator and its still misfiring.
                  • iamsam
                    • Jun 2008
                    • 174
                    ok we re-did the engine grounds, replaced the lower one and re-attached the upper one, still missing,
                    Any more ideas of what it could be??? any help is appreciated!!
                    • structured
                      • 954
                      I was just trying to fix my misfiring issue yesterday. I changed the fpr and tried to clean the distributor cap and rotor, neither of which made a difference. I did, however, notice that the crankshaft vibration damper (or the main drive pulley) is vibrating excessively. So much so that I think that it is making contact with the water pump pulley.
                      I have a theory that this may be the source of my misfire because the crankshaft position sensor may have been hit or otherwise damaged by the vibrating pulley.
                      • iamsam
                        • Jun 2008
                        • 174
                        definitely keep this thread updated if the crank position sensor fixes the problem or not.
                        Sam and I have pretty much decided that the only way to fix his M20 misfire is to replace the M20 with an M50. :D So that may be next.
                        • DTMbimmer07
                          • 1485
                          Has one figured out what the problem is?
                          • iamsam
                            • Jun 2008
                            • 174
                            nope, he took his car off the road, and is driving his old Saab again, his E30 is now hos project car, because we can't get it to run right.
                            • sticksdaman
                              • Apr 2005
                              • 2987
                              Why is it that nobody can figure this problem out? I've been having this issue for nearly 5 months now and still nothing. It's beyond frustrating.
                              Originally posted by ebelements
                              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                              • iamsam
                                • Jun 2008
                                • 174
                                i think the only solution is that M20s suck. its time for Mr. M50.
