Need help identifying a new noise
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    The other day I replaced the headgasket (leaky oil journal fouling my garage floor) and the front cam seal (same). Now, there is a loud, rapid tick from the front cam area that sounds like a wickedly mis-adjusted valve, but much faster. It's so rapid it's almost a hiss. It wasn't there before, and it's the loudest thing in the engine bay now. I took video, hopefully the audio is good enough to make out what I'm saying. Note, I'm not talking about the normal m20 sewing machine noise, this is much louder, faster and higher pitched. Any ideas what it might be?
  • ThreeTwentyFissel
    • Apr 2009
    • 220
    Manifold Bolts?
    Simplicity is your best option!
    • CorvallisBMW
      • 13039
      Originally posted by ThreeTwentyFissel
      Manifold Bolts?
      Never loosened them, I disconnected at the downpipes. Never disconnected the intake manifold either, I lifted the whole thing off in one giant chunk.
      • Ruffian
        • 378
        All i got for you is a mismounted rotor tapping the posts in the distributor or fanblades hitting/knicking something.
        With it's frequency, I'd look at the externals on the front rather than inside where your ticking would be by cylinder and not all the time.
        Keith
        "Die feine Art, schnell zu sein."
        "I don't have a gambling problem, my gambling pays for my e30 addiction."
        • RedTRex
          • Dec 2008
          • 249
          double check your timing - sounds to me like the belt is off a few teeth ...... granted vid sound capture gets a bit attenuted - nonetheless - it has a touch of diesel sound to it ... I did that on an M20 I had before.
          Leave now before I shed my human form and kill you
          • E30SPDFRK
            • 5716
            Fan hitting the shroud?
            Byron
            Leichtbau
            • CorvallisBMW
              • 13039
              I had to take the front end apart again to replace a leaky O-ring, and after putting it all together the noise seems to have disappeared. However I also did a valve adjustment, and they actually got louder. Gotta re-check the clearances in the morning.
