Off-set valve keepers available?
  • Chuckcruzin1986
    • Jul 2009
    • 130
    Hi,
    I heard that there are off-set keepers, maybe .050" which tightens the springs a little and makes up for a valve grind.
    Is there such a thing for a M20 885 head?
    thanks, Chuck
  • Mike
    • 932
    Do you mean over sized eccentrics? Try bmpdesign
    Supatek -noun - your basic know it all
    • whodwho
      • Jun 2008
      • 1547
      Sounds more like valve spring shims???
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • NC325iC
        • Mar 2004
        • 6565
        neither of those things would tighten up the springs. I am unaware as to if there is anything though, if there is VAC would probably sell it.
        • Ruffian
          • 378
          Picked up a couple oversized eccentrics from bmp, and they also have valve caps.
          Keith
          "Die feine Art, schnell zu sein."
          "I don't have a gambling problem, my gambling pays for my e30 addiction."
            Tightening the springs won't substitute for a valve job. If the valves are won and leaking, tighter springs won't stop those leaks.
            • whodwho
              • Jun 2008
              • 1547
              And how is it that valve spring shims would not tighten the springs???
              FYI, From grinding seats and valve faces will increase the installed height of the valve spring measured from spring retainer and spring seat/pocket. Shims are used at the base of the valve springs to increase tension back to proper seat pressure.
              He did say "makes up for a valve grind" so sounds to me like he has this covered
