Ticking Noise
  • v8fc3s
    • Apr 2009
    • 105
    Ticking Noise
    Hello, recently i was driving my 87 325i cabrio when i noticed a ticking noise. I have taken the car to a mechanic and when he drove it around, he said its not the valves. He sais its the rod bearings. My question is, can i remove the crossmember and get at the rod bearings without pulling out the engine?
    Thanks in advance.
  • Dirtbleed
    • 495
    That ticking sound is your motor running fine. When it stops ticking, you have a problem.
    • v8fc3s
      • Apr 2009
      • 105
      No because what i forgot to mention is that its not ticking the whole time. It gets lounder when you stay around 3000rpm or higher and the engine is not under load. When the car is accelerating it sounds fine. But anyways, can i get in throught the bottom or not?
      • scaraveos
        • Jun 2008
        • 28
        the cross member you are talking about holds the engine. so unless you hold the engine from the top of it you cant remove it.
        Track Addict! Going Insane!!!
        http://p-bmw-e30.net
        http://ep82.net
        • SpecM
          • Oct 2005
          • 4531
          is is "ticking", or is it a rod "knocking"?
          1989 cirrisblau-metallic 325i
            • 34844
            sounds like you just need a valve adjustment
            • learningcurve86
              • May 2008
              • 715
              ^^^ thats a much easier and cheaper thing to try out too. May as well start with something you could do on your own if you wanted to 'learn while doing'. my $.02
              Greg
              • v8fc3s
                • Apr 2009
                • 105
                i thought it was the valves as well but the mechanic said it was too loud to be the valves, and it is a rod knocking, but the reason is because of the bearings
                • whiltebeitel
                  • Apr 2007
                  • 2098
                  What kind of cars does this mechanic usuallly work on?
                  '89 325i track sloot
                  '01 530i daily
                  -Enginerd
                  • SpecM
                    • Oct 2005
                    • 4531
                    valves/rockers can be pretty noisy on an m20 thats out of adjustment
                    try it first, then see how it sounds
                    • Wh33lhop
                      • 11705
                      Just do the damn valve adjustment, it'll take you half an hour.
                      paint sucks
