It would appear it's time to do some maintenance work on my engine. I have never done any serious engine work, so I thought i'd run my plan by someone else. So far the plan is to replace the water pump, fan clutch, and timing belt. Here is my parts list so far:
Timing belt
Water pump w/ gasket
Fan clutch
Valve cover gasket
Timing belt tensioner
Rocker shaft gaskets
Cam seal and o-ring
Other necessities for the job:
Coolant
Gasket sealant
Fluid catch pan
I think thats everything I have. Am I missing something or should I replace anything else while i'm in there? Also, any words of advice/warning would be appreciated.
Timing belt
Fan clutch
Valve cover gasket
Cam seal and o-ring
Coolant
Gasket sealant
Fluid catch pan
