Can I replace the water pump without touching the timing belt?
  • eek142
    • Apr 2009
    • 78
    Car has been running warm recently and I've decided to just replace most of the cooling system since the parts have been sitting around now for a while anyway.
    The timing belt was replaced a few thousand miles ago by the previous owner, so it's still good. I've researched and asked around, and I'm seeing differing opinions on whether or not I can install the pump without undoing the timing belt.
    The car is a 1989 325i. Will the tensioner spring pose a problem? Can this job be done without releasing tension from the timing belt so I don't have to buy a new one?
  • bmw325csi
    • May 2007
    • 4045
    yes you can
    Its quite simple, take the radiator out for ease.
    harry/harout
    • eek142
      • Apr 2009
      • 78
      Will I need a new accessory belt to run it? I read the old one is a pain to get out, so I was thinking of just snipping it.
        The pump only can be replaced but the timing belt tensioner will cause grief. it bears against the pump and you have to fight the spring to get the pump back in. It is almost impossible to accomplish that single-handed and just barely possible with two people. Since there isn't anything other than the bolts to index the pump, damage to the gasket when wrestling it into pump is very possible.
        I've done just the pump, once. As cheap as a belt is I won't do it again except in an extreme emergency.
        • tinkerputzer
          • Jun 2008
          • 508
          The water pump can easily be changed separate of the timing belt. Just don't loosen the bolts for the t-belt tensioner.
          The trickiest part about changing the water pump is dealing with the tensioner spring. A trick for this, before installation of the water pump, is take the pin and spring and push it as for though the hole in the tensioner as possible then lock onto the exposed portion of the pin with a small vise-grip. When the water pump is bolted in place, just release the vise-grip so the tensioner spring and pin sit in the detent of the water pump.
          As for the accessory belt, I believe, you'll have to take off the other belts in order to replace the alt/wp belt.
          • bmw325csi
            • May 2007
            • 4045
            Thats why you remove the radiator and do it from the front, takes twenty minutes to remove but it saves you tons of grief
            harry/harout
              • 34844
              you don't need the spring if the tensioner is bolted down. it's only there to set the tension while you tighten everything. leave it out when you bolt up your waterpump.
                • 34844
                and actually, why are you changing just one. they have the same service interval, and the parts are only like $30. just do both.
                • eek142
                  • Apr 2009
                  • 78
                  Thanks for the advice everyone.
                  Well, the previous owner never changed out the water pump from what I understand, but he did swap the timing belt a few thousand miles ago. The cooling system seems to be pretty old anyway, so I thought I'd take care of it now - especially with the car acting funny.
                    • 34844
                    ah, that makes sense I guess.
                    make sure the tensioner bolts are tight, and go for it..
                      • 37833
                      I has no spring in mine. :)
                      Grover Beach, California
                      BimmerHeads.com
                      • Sirotto
                        • 317
                        Change the belt. You are talking a 35 dollar part and at least 4 hours of labor. Unless teh prior owner can show you when he bought the new belt and tensioner and has pictures of him putting it in I would change it. But yes can change the pump without changing belt, but why would you?
                        "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
                        "People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
                        • Wishno87
                          • 6025
                          +1 just do it. Im doing a water pump too right now and im changing my belt and tensioner even though they only have 25K on them because they are RIGHT THERE!!
                          • ZM Blue Devil
                            • Dec 2006
                            • 13836
                            +1 for doing it all.
                            Levent
                            %20levent@gutenparts.com
                            Ladies:
