Big Radiator for my 325i
  • DarKane
    • 14
    Guys i need a bigger radiator for my e30.i am looking for something with expansion tank so i can get rid of the stock separated expansion tank.any suggestions?
  • Emre
    • Sep 2007
    • 1228
    If the integrated expansion tank is your main priority, you can always bolt on a rad from the 1991 318is with M42B18 engine. It's got an integrated tank, but it's a bit smaller than that on the 325is.
    If you want both the tank and larger capacity, you'll have to move up to an aluminum racing rad: http://www.bimmerworld.com/html/pwr-...9-e30-325i.htm
    1987 Mercedes 190E 2.3-16: Vintage Racer
    2010 BMW (E90) 335xi sedan: Grocery Getter
    • Van Westervelt
      • 9365
      Why do you want an integrated tank? Just to clean up the bay?
      I do not believe any of those tanks on the bimmerworld site have expansion tanks built in. My PWR rad doesnt.
      IMHO Rad's with plastic ends and plastic expansion tanks are asking to fail. Get an all alum rad, and keep your tank where it is.
      Go with the PWR 57mm :)
      • DarKane
        • 14
        i live in a crap country and I cannot find high end racing parts so i have to improvise from other BMW models :-(:-( i was thinking about the radiator from e36 325 but i don't know if it needs modding to fit in
          Unless you've done something to significantly increase the power, the stock radiator is good enough. I think it is possible to fit an E36 radiator in an 89 or late if you want to go down that path.
          • SpecM
            • Oct 2005
            • 4531
            ^ agreed, just make sure the rest of the system in good shape (new w/p?) and well-bleed
            1989 cirrisblau-metallic 325i
              • 37829
              An M42 radiator can cool a 6 cylinder just fine, even an S50.
              I doubt you need a bigger radiator.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
                • 34839
                yeah, it sounds like he just needs a new one.
                • Wh33lhop
                  • 11705
                  Yeah, M20 radiator is way more than enough for an M20. When does the car overheat? Have you checked the fan clutch? Checked and bled the coolant? Are you blowing white smoke? Could be a number of different things.
                  paint sucks
