super ETA spark plugs
  • 884door
    • Nov 2008
    • 380
    What are the proper spark plugs for an '88 325?
    All the documentation I can find reccomends a different plug for an m20b25 compared to an m20b27, but since the 88 "super-eta" has an 885 head I'm a bit confused which type of plugs to use? I'm guessing anything that works in a 325i will work in the super-eta?
    Thanks guys.
  • reelizmpro
    • 9558
    It should be W8LCR which is now WR8LC or something like that. WR8LC+ has an yttrium conductor for longer life. 325e WR9LS has a silver conductor and are very expensive.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • 884door
      • Nov 2008
      • 380
      Thanks, new plugs in place :)
      Old ones had oil on them though :(
      I hope its leaky valve stem seals and not bad piston rings. I need a compression tester.
