I diagnosed the problem and didn't hear anything from the in tank pump when the ignition was in the on position, so I replaced the in tank fuel pump. Worked fine for a while then cut out, not I think the fuel pump relay might be the culprit.
The car turns over and even starts but cuts out in 2-3 seconds and doesn't respond to throttle input at all. It just dies out even as I pump the accelerator. All the other electrics work fine it just won't start. Charged the battery up and it held voltage, and the tank is atleast half full but still it won't stay on for more than 3 seconds when it finally does start. Could it be as simple as the relay or is there something else which could mess with the fuel delivery??
