ix m20 into is..
  • 4ce30
    • Feb 2006
    • 2762
    ix m20 into is..
    Ive got a blown 89 325is and i just bought a running m20 out of a 91 325ix..
    My first problem obviously is the oil pan situation which i have luckily.. Next probelm i can see is the dipstick is in a different place on the block and the oil pump situation. NANDO says you need to swap out the intermediate shafts and some maching to get the pump to work.. Is all this worth it for a solid running M20 or should i just find another?
    -Brandon
  • lennon
    • Jun 2008
    • 1416
    doesnt the ix motor sit at a different angle?
      • 34847
      the biggest issue is the oil pump. you can't just bolt on an is oil pump to an ixblock.. you'll have to do some maching. also the intermediate shafts need to be swapped. the other problems are minor.
      • 4ce30
        • Feb 2006
        • 2762
        Appreciate the feedback, i noticed the oil pump has a bracket that goes to the main and i wouldnt want to F with that.. i might just put this oilpan back on and keep this engine complete and go with another one.. Ibought the engine for a great deal i couldnt pass, do you think its worth the trouble or should i look for another block? thanks
        -Brandon
        • kishg
          • Sep 2006
          • 2624
          just find an is m20, they are dime a dozen.
          '12 F30 328i Sport Line
          '91 SpecE30 #523
          '00 Ford F-350 Dually Tow Vehicle
          BMWCCA #360858 NASA #
          128290
          • 4ce30
            • Feb 2006
            • 2762
            true but i just purchased this motor and its in really really really good codition.. :???: shitty...
            • kishg
              • Sep 2006
              • 2624
              sell it to an ix owner with a blown motor :)
              '91 SpecE30 #523
              128290
              • 4ce30
                • Feb 2006
                • 2762
                Looks like im on the hunt for another engine.. thanks NANDO your the $h!t
                • aaron325ix
                  • Jun 2007
                  • 1489
                  I am on the hunt for an iX motor to rebuild, if your looking to get rid of it. PM me if interested. Even just the bottom end would be fine for me.
