Spark plug wire part number for early 1987 325is?
  • sonick
    • Aug 2009
    • 48
    I have an early 1987 325is (coolant reservoir on passenger side), what is the correct ignition wire set?
    All I've found indicated that the wires for 325is were only for those built from Sept 1987. The sticker on my car says it was built in June of 1987.
    The ones for pre-sept 1987 built E30's are only for the 325/e/es engines. Mine is not an eta.
    Thanks for your help!
  • !kid
    • 1362
    :borg:
    • reelizmpro
      • 9554
      Just make sure you get a 325i wireset with inductive pickup sensor.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • einstein57
        • Jun 2007
        • 10780
        I ended up getting wires from ireland engineering. It was cheaper then the factory replacement
        www.gecoils.com
