UPDATE: The idle and accelerations problems seem to have disappeared, but the car is running pretty rich and when the car is stopped at a light and idling, after a few seconds the check engine light comes on. It stays on until I push the accelerator pedal and then it goes away. Today I installed the chip and things are unchanged. I did notice that the car seems to lag worse than usual when I step on it until about 4000 rpms. I know usually people say coolant temp sensor or oxygen sensor, but it seems too coincidental to be either of those since I wasn't having any problems prior to this wave of part installation.
Recently I installed some E36 17.5 injectors and a new TPS. The car seemed fine for the first few drives, then the check engine light starting coming on for just a second (happened like 3 times during different driving sessions). Now the idle is all over the place and when I give the car gas it will feel normal and accelerate, then jerk backward like someone has cut off the fuel or stabbed the clutch all of sudden. It will alternate between jerking forward (positive/normal throttle response) and back (no throttle response). I imagine is has to be something I did wrong, but I can't figure it out. I had a look over the motor a few times looking for vacuum leaks or cracked hoses and all I could find was some cracks in the little hose that goes from the idle stabilizer valve to the throttle body so I replaced it with a new one. After that the problem is persisting.
Is it possible that it's behaving like it is because it needs a chip for the new injectors? I wasn't having any of these problems before I replaced the injectors and tps. I am also fairly certain that the TPS is properly adjusted. I followed the protocol in the Bentley so that the two pins show 0 ohms and I also looked at the marks left by the mounting screws on the old unit and they appear to be in the same place so I don't think it's the TPS, but I am human so I could have effed up somewhere.
The car is a 1990 325i w/ manual transmission. Any ideas about what might be going on here? I have a Mark D chip on order and am just waiting for it to get here.
Thanks in advance!
Thanks in advance!
