Riddle me this?
  • rvaughnp
    • 136
    Riddle me this?
    2.5 Deck height 206.1
    Internals:
    Stroke - 75 stroke (37.5)
    Rod - 135
    Piston (Compression height) 34.2
    206.7
    Measurements taken from http://www.bmwccn.no/rogaland/Mahle_m20.html
    Edited picture from original.
    Got it. (edited)
  • fiftytakedowns
    • 2460
    I think the top of the piston (edge) is still flush wiht the edge, thats just the dome FOR SUPARRR compressionz
    [/url]
    Team USA Wrestling 67KG
    • rvaughnp
      • 136
      The black ring in between the white lines is the side of the piston sticking out. Sorry for the not so sharp pics, my camera is not working with my laptop.
      --Edited pic up top.--
      • Rob
        • 8166
        would be level when there's a head gasket maybe?
        BEERTECH
        • Conrad311
          • Oct 2009
          • 368
          I think the clearances would be so close even with the head gasket that the it could do some damage. And the compression ratio would be higher and high rpm combustion pressures would probably blow out the head gasket.
          did you measure your block specificly? if not is there any chance of the deck being machined before? could account for the numbers being off
          "In God we trust. All others must bring data." -W. E. Deming
          /// 1987 325is /// Project Thread
          Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.
            • 34827
            it's completely normal. it makes for a good quench area in the combustion chamber (note how the 885 head is shaped like the tops of the pistons).
            • 2002maniac
              • 4260
              don't pull a jordan. :) Make sure you check valve clearances once you've got the head on.
              • rvaughnp
                • 136
                I realize all the previous posts. I guess i didn't make the question clear enough.
                My question is in the 206.7.
                If the centerline measurement from crank to deck of the block is = 206.7 and the: stroke/rod/piston = 206.7.
                Why is there a 1mm (or so) actual difference?
                I will be checking clearances prior to starting anything. Just curious if anyone knows where the difference is coming from?
                  • 34827
                  well you are trusting measurements off the internet. That's where I think the error probably is.
                  • SpecM
                    • Oct 2005
                    • 4531
                    ^ he's right, all the b25's and s-eta have a domed piston like that
                    1989 cirrisblau-metallic 325i
                    • rvaughnp
                      • 136
                      You refering to the "actual" length/height of the crank/rod/piston ratio?
                      But these are "common" known measurements for the above mentioned items.? Well, some thought the 206.2 was common on ETA blocks, I guess its time to physically measure mine.
                        • 34827
                        yeah, that's another error. eta blocks have the same deck height.
                        all I know is it's normal for it to stick above the deck.
                        • rvaughnp
                          • 136
                          I posted http://www.r3vlimited.com/board/show...01#post1689001 info that should put that ETA misunderstanding to bed.
                          I will try to get the crank out to measure the block and then measure each individual part. It is only a curiosity to me... but may make a difference to others that are trying to figure CR or whatever else.
                          Thanks for replies.
                          • rvaughnp
                            • 136
                            yeah uh... Thats not going to happen. Trying to measure the block, rod, piston, crank through???... with a Autozone bought micrometer in a garage for a missing mm. Not.
                            I guess that curiosity of mine will have to subside.:hitler:
                            • rvaughnp
                              • 136
                              Potential answer from Aptyp:
