NV m50 Engine Management on e30?
  • Aptyp
    • 6584
    Has anyone considered doing that on m20 engine? With WAR chip air flow and all the fun stuf can be adjusted, but it would also make a lot of management for turbo m20 a lot easier.
    Tell me what you think.
  • yberther
    • 1246
    here is an interesting thread on what you're thinking.
    Flickr
    Originally posted by Indecline06
    For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
    • Aptyp
      • 6584
      thank you, bud
        • 34834
        if you can work something out with the trigger wheel, the 413 ECU is a much better choice - pretty much better everything. I talked to Matt about it and he said if you got it running, TRM could even burn a custom chip for you.
        the NV is just easier because the trigger wheel is the same. the vanos engines still use a 60-2 wheel, but it's a hall sensor and it also has a different sensor angle.
        • Aptyp
          • 6584
          As I'm wrecking this in m head, I am realizing, it's cheaper to just plug m50NV into e30 as a whole. :) I have an engine laying around I got with all accessories for $200 out of a e34. I am pulled into too many directions.
            • 34834
            it would probably be more worthwile on a modded M20, or just for the heck of it to see if you can do it. NV M50s don't excite me, though. :p
