oil return tube
  • Nic01101011
    • Jan 2008
    • 1549
    oil return tube
    when i was putting the head back on i didn't put the o-ring back in the bottom of the spring loaded tube, would that cause a bad enough vacuum leak to idle really shitty?
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    it will probably leak some oil
    -Andy
      Yep that would be an intake leak and will contribute to a rough idle as well as be an oil leak.
      • whodwho
        • Jun 2008
        • 1547
        It wont be a vacuum leak but can allow non metered air (air to the intake that has not gone thru the AFM) which would effect the idle.
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • 34847
          you're going to leak a lot of oil without that o-ring
