Here's the story...My daughter was just driving along going 60 and the 325es just quits running. I tow it home and run some tests. Here is what I have done so far.
changed fuse 11 with different fuse just to be sure that was not the issue.
Jumpered the fuel pumps at the relay and both pumps turn on. The bentley says to test for voltage across relay terminals 85 & 86 while cranking and if not present then the main relay has a problem.
tested main relay and not getting any voltage between relay terminal 30 and ground.
Tested junction block for 12v on firewall and it does have voltage.
Tested ECU harness to try and get injectors to fire and nothing.
Looked at fusable link in trunk and it looks good as nothing is melted.
Tested for voltage supply to ECU from terminals 18 and 35 to ground and no voltage is present...of course the main relay was not in place at the time!
What could be the problem?
