I'm getting frustrated. Here's the deal: I pulled the drivetrain (dropped w/ subframe) to swap the clutch. Put everything back together. Now it will crank like a champ, but has no fuel going to the rail. The main relay buzzes w/ ignition turned on & while cranking. Engine is a 2.7i running Motronic 1.1.
What I've done/checked so far:
-rechecked harness connections @ firewall & grounds
-swapped in new 30A fuse into #11 slot
-swapped fuel pump relays
-jumpered fuel pump relay & I got PLENTY of fuel flow to the rail
-checked voltage @ main relay (#30 & #86) and have good juice
-checked voltage @ ICV & all seems well
I'm leaning toward a new main relay, but Bentley says if I have good power to the ICV, then "the relay is probably working." If it's the main relay, fine. I'd just like to know why it decided to fail now?
