m20b25 with m20b23 crank?Resulting a 2,3?
  • -Jelko-
    • Apr 2008
    • 238
    Well as i heard using crank of b23 in b25 would result in 2,6 displacement,well the thing is i can probably get b23 crank for dirt cheap(if not free?) and finding eta is hard as shit.Since i like to experiment this is also nice lil project since i got b25 in parts ready to be rebuilt.Can anyone confirm this info to me?
    EDIT:wrong title...resulting in 2,6? :P
    I www.ak-bmwcroatia.com I
    :wgaf:
  • -Jelko-
    • Apr 2008
    • 238
    der bump
    :wgaf:
    • SpecM
      • Oct 2005
      • 4531
      not so sure about this dude, we didn't get 2.3s in America...
      what is the stroke of an m20b23?
      1989 cirrisblau-metallic 325i
      • M-technik-3
        • 18946
        What rods are you planning to use?
        • eta
          • 63
          A 2.3 cracnk (76.5mm stroke) in a B25 block would require custom pistons as the stock 325i pistons would be 1.5 mm to high. If you shave the 325i pistons you will remove the meant to be threr pertrusions which aid squish.
          Also the displacement would be 2554cc as used in the Alpina C1 2.5. Its all be done before.
          • E30_fiend
            • Apr 2006
            • 7348
            So really if one purchased custom pistons to match the i rods, would this still be atainable?
            • -Jelko-
              • Apr 2008
              • 238
              Thanks dude,that was answer i was searching for!
              :wgaf:
              • SpecM
                • Oct 2005
                • 4531
                huh, with that stroke (76.5mm) an m20b23 must have a very small bore...
                • Stu
                  • 4083
                  320/323 were based on 80mm bore. In the mid-80's, hot M20's were overbore 84.4 on 76.8 (323i crank) @ 2580cc. 210+hp M20's were not uncommon in '83-'84, even with U.S. 93 octane.
                  • Holland
                    • Nov 2008
                    • 7212
                    If this is true then wtf are we so concerned with 2.7 strokers?
                    Originally posted by DEV0 E30
                    • digger
                      • Nov 2005
                      • 6191
                      because a 2.7 has more power and torque potential when done properly and the 81mm cranks are more common
                      • eta
                        • 63
                        And C1 2.5 did not have 210+hp. Only the 2.7i C2 had that.
                        • Stu
                          • 4083
                          I meant that there were options utilizing short-stroke engine parts to make fairly substantial power, before the 325i was introduced. Surely an 81mm stroke will make more power yet.
