Short backstory: Lost compression in cylinders 2 and 5, Have ETA block sitting around, Building "low compression budget stroker" (boosted), rocker arms are brand new, Thinking about getting coolant channels welded, Getting head checked and resurfaced before it goes back on.
I have been reading a lot about DIY port and polishing and recently have been practicing on a junk eta head. I started with the the exhaust manifold, gasket matched it and feathered it in. Now when I look at the I head(885) I notice that there really is no need to gasket match because the gasket is slightly smaller than the I head and manifold. My question is, is it recommended to port the exhaust side only if I were to run boost via supercharger? Would the uneven porting be harmful or at least barely beneficial?
Thanks guys!:D
Thanks guys!:D
