What size injectors?
  • RowdieRowd
    • Jan 2009
    • 34
    What size injectors do you recommend for an n/a 2.7i just a stock rebuild with the i head and i top end. I'm planning on boosting it soon after i break the motor in but what size injectors do you recommend for na and or turbo?
  • Danny
    • 14216
    19 for N/A 24 for turbo.
      • 34839
      24# are small for an M20 turbo - 32# minimum for a turbo, preferrably 42-60# if you're going to do more than 8-10psi.
      I would do 17# M50 injectors on an otherwise stockish M20 (2.7i counts as stockish in this case).
      • JTapper
        • Sep 2009
        • 847
        I'm working with Miller Performance on my M20 turbo project, they recommended 30#, I'll be running 12psi max.
        Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
          • 37832
          I'd do M50 injectors.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
