ok so wtf..?
    ok man. sounds like a plan. Ill see what i come up with. I appreciate it
      good luck let me know what you find
        The only reliable method of
        locating intake leaks is to have a smoke test run on the intake and crank case
        and to test the brake booster with a gage and vacuum pump. The complete list
        of possible causes of an intake leak is:
        Intake boot
        Throttle body gasket
        ICV hoses & connections
        Brake booster, hoses, and connections
        Crank case breather hose
        Evaporative control hose and valve
        Fuel pressure regulator & hose
        Injector seals
        Valve cover gaskets & bungs
        Oil filler cap
        Dip stick o-rings
        Oil return tube o-rings
        While leaks in some of those can be found by inspection or by spraying carb
        cleaner on suspect areas, not finding leaks that way doesn't eliminate the
        possibility. Only a smoke test will really work.
