Can e30 M3 firewall covers fit m20 cars?
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    I've ordered all 3 pieces to the e30 M3 firewall cover, and after poking around in my engine bay for quite some time, there is no way I can see to make these fit without some decent modification. The M20 wires sit too low on the firewall to fit in the cable holder, and the battery tray piece won't fit because of the huge wire coming out of the firewall from the ECU.
    I know I've seen lots of 24V guys do it, but can it even be done on an m20 or should I just return the bits and get my $45 back?
  • CorvallisBMW
    • 13039
    really? nobody?
    • transatlantic0207
      • Sep 2007
      • 1624
      I want to know this too!
      (OO≡≡[][]≡≡OO) ///Motorsport
      In this world, things aren't black & white. Its Delphin!
      Parts, Buy Them--> http://picasaweb.google.com/transatl...eat=directlink
      Snowboard & video game stuff --> http://r3vlimited.com/board/showthread.php?t=148645
      Originally posted by Steve92E34
      Your car is breathing my air, and so are you.
      AND you are both still slow
        • 37829
        I have not personally done it but I know for a fact that it's been done.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Slyder
          • 348
          Not sure what's so hard about it. I've done this on several cars. You'll need to do a little bit of trimming on the factory heat shrink tubing (that by now is hard and brittle). You can either put it into corrugated tubing or wrap the wires in electrical tape to compress the wires and fit them inside the case.
          These covers were included in both e30 M3s and the facelifted 318i/is/ics. Here's some photos from my NA m20 install and my current turbo project.
          NA Setup:
          Turbo Setup:
          - Jason
          • Dirtboy
            • 458
            Originally posted by Slyder
            NA Setup:
            Man that looks nice! I hope I can get this to work on mine. I pulled the cover off a 318 from the junk yard. It didn't come with the piece over the battery tray though...
            Nürburgring info
            • xwill112x
              • Jan 2009
              • 4236
              aren't the m3 one's the same as the 318i/is ones?
              • kencopperwheat
                King of Kegstands
                • 14396
                Yes, but the M3 also has the one by the battery tray.
                Originally posted by Gruelius
                • mistacarder
                  • Jan 2013
                  • 289
                  where did you buy the cover?
                  Instagram: @mistacarder
                    • 34839
                    fits on mine..
                    it's not an M20 harness, but I'm running the stock power wires in there.
                    • Cabriolet
                      • 9620
                      no issue at all.
                      remove the metal bracket holding the wires.
                      cut 2 of the studs off. drill holes through the new backing plate. mount and then wedge all of it in. it's a tight fit at the back of the intake manifold. and if you have a poorly mounted engine, i could see it not fitting at all.
                      IMG_7563 by Eric Berger, on Flickr
                      IMG_7562 by Eric Berger, on Flickr
                      Much wow
                      I hate 4 doors
                      • Luis325
                        • 3847
                        Anyone have the part #'s for these covers?
                        1986 "C2 2.7 Alpina" Sedan
                        1987 325ic Black Vert
                          • 34839
                          www.realoem.com
                          look under the E30 M3. they aren't really that expensive either.
                          • E30_fiend
                            • Apr 2006
                            • 7348
                            Blunt has them for like $70 shipped if I recall correctly.
                              • 37829
                              Still need to do mine! Looks great Eric.
                              Grover Beach, CA
                              www.BimmerHeads.com
