Timing belt cover problem
  • ariasoli
    • Jan 2010
    • 6
    I just finished installing a new timing belt and water pump. I was then installing the upper timing belt cover and I cant get the bolts to go all the way in, could the metal guides be causing a problem or did I possibly mess up the threads on the block?
    Any suggestions? Thanks
  • White325is
    • Oct 2006
    • 5947
    did you put the metal hook back on behind the upper cover?
    • ariasoli
      • Jan 2010
      • 6
      Yea, at first I forgot but I did after and it was still giving me a problem.
      • SpecM
        • Oct 2005
        • 4531
        could be like mine... the threaded hole in the head that the cover bolts to is stripped out... maybe
        1989 cirrisblau-metallic 325i
        • ariasoli
          • Jan 2010
          • 6
          I think thats what it is. What do you recommend??
          • SpecM
            • Oct 2005
            • 4531
            push the bolt in as far as it will go and check it every time you pop the hood?
            • FredK
              • 14764
              So are both bolts not threading in, or just one of them?
              • ariasoli
                • Jan 2010
                • 6
                Lol so much for torquing it down.
                • ariasoli
                  • Jan 2010
                  • 6
                  At first one but now both of them.
                  • SpecM
                    • Oct 2005
                    • 4531
                    both?
                    maybe your cover is bent? did you sit it on the ground? in the sun? where children could reach it?
                    • ariasoli
                      • Jan 2010
                      • 6
                      Originally posted by SpecM
                      both?
                      The bolts dont screw in properly even without the cover on. I really think the holes are stripped.
                      • karpiel
                        • Oct 2009
                        • 87
                        Funny how threads magically screw themselves up when no ones looking.
