Thank you very much jlevie, all the help is really appreciated.
Odd Lean out problem, running out of ideas
Update: Got the correct temperature sensor, problem is still happening. Beginning to think that I missed something with the TPS. Noticed that if I go WOT until it starts to lean out, and then back off a hair on the throttle, AFRs come back into an acceptable range. I assume that by letting off a tiny bit, the ECU is going back into cruise mode even though it is still accelerating hard. So, is it time to look for a new TPS?
Originally posted by kennedy View Postwhat wide bandare you using and how old is it. they go bad as well the ethanol kills them. borrow a friends or do a back to back coparison with a fresh one. or make a pull then check the plugs they arent gonna lie to you and if your unsure then post a pick
The afm is from 89...dunno if there is such thing as a "new" afm anymore.
oh, and the crankcase is venting to a oil catch can. Not to the intake manifold. Doesnt matter though, because the same thing was happening with the oil catch and without.
