Ok... Got the pistons and crankshaft, What else do I need?
  • boricuabimma'
    • 566
    Ok,
    I got for free a set of 528e pistons + crankshaft.
    What else do I need to make the 2.8i stroker??
    The I head is on it's way
    1994 BMW 325 i/Canon Rebel XT/28-135mm IS f:3.5-5.6/Canon 50mm f:1.8
  • Rob
    • 8166
    1986 BMW 325 2.8i | M-Technic 1
    should be on there.
    BEERTECH
    • boricuabimma'
      • 566
      thanks ;)
      • Jon325i
        • 6934
        Originally posted by Rob
        http://www.strictlyeta.net
        should be on there.
        You stole my thunder Charlie :x
        Jon
        Rides...
        1991 325i - sold :(
        2004 2WD Frontier King Cab
        RIP #17 Jules Bianchi
        • Rob
          • 8166
          charlie?
          BEERTECH
            • 37829
            :ohsnap:
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Jon325i
              • 6934
              charlie?
              You two yoots have that same crazy symbol thingy in your avatar. I'm always getting you two confused :?
              Now I feel like an utter tool :oops:
              Jon
              Rides...
              1991 325i - sold :(
              • Jordan
                • 12913
                you cant make a 2.8i with super eta pistons. Only a low CR 2.7.
                not all 528e's have super eta pistons, only 88's
                https://mtechniqueabs.com/
                • boricuabimma'
                  • 566
                  so I can't make neither 2.7i nor 2.8i proyect with pre 88's 528e pistons??
                  why is that?? I mean, what differences does it have?
                  • Jordan
                    • 12913
                    a eta bottom end with a i top end makes a very low CR 2.7L engine.
                    • boricuabimma'
                      • 566
                      so It doesn't matter if I have a pre 88 528e pistons, it will be Low CR??
                      If I shave the head, can that help?
                      • Jordan
                        • 12913
                        I would not shave the head... rather deck the block.
                        In all seriousness why build a halfass stroker like that? Spend a little more and obtain some super eta pistons. At least then you will be a bit better.
                        • boricuabimma'
                          • 566
                          I'll be more than happy to invest in super eta pistons...
                          If I find them
                          • Sean
                            • 5793
                            I'll be doing the normal Super Eta stroker - I was thinking I'd get the head shaved. But, you're saying to get the deck the block (shave that down a bit - in other words?). I'll want to do that if I want to remain N/A, right? My friends are trying to get me to go turbo, but I want to stay N/A.
                            - Sean Hayes
                            • Jordan
                              • 12913
                              Don't shave the head. Better to deck the block, and get a offset cam gear pin to correct the timing.
                              I still have a hard time with the super eta piston strokers. They still produce a low 8.8:1 CR.
                              But ig you are on a budget, they will save you some money.
                              My 9.5:1 85mm JE's were ordered awhile ago, should come in soon.
