WTF is wrong with my engine !
  • KillaCam
    • 2103
    Ok I have a m20b27 85 235 e I just recently blew a fuse and I figured out it was a light that was the wrong voltage or something ( might have something to do withthe problem) But the issue withthe engine is between 2 and 3 rpms the engine seems to choke out. It would putter but when I floor it it would get up and go puting out more power than I have seen buring out. Then I switch gears to second then it does everything all over again. I once had a problem with the o2 sensor and replaced it with a junk yard find. It is also idling at 500 rpm and you can hear a weird inconsistancy in the engine. I haven't changed The plugs since I got the car. I think I mght have a vacume leak. If you might have any idea let me know and don't hate on any miss spelled words I am typing this on a iPhone.
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
  • IRON-E
    • 16548
    Start here = fuel filter, spark plugs (Bosch Super), Change your rotor cap, clean your ICV and get back to us.
    @IRON-E30 aka Edwin:D
    • KillaCam
      • 2103
      Ps I CAnt find any leaks from a vacume hose and the plugs are tigt and there is a wire loose and unpluged by the fire wall and but I couldn't find anyplace to pulg in in. It's been unpluged since I got it.
      • IRON-E
        • 16548
        can you take any pix?
        • KillaCam
          • 2103
          Well it could be my Icv I took it off cleaned it then put it back. But I think I am going to pick one up at the junkyard
          • KillaCam
            • 2103
            Well I could if it wasn't dark out , raining, and the fact I'm about 20 miles from the car. But when it's brighter out and whenim home I'll jump on it.
            • KillaCam
              • 2103
              btw I fixed it. It was a hole in the fuel line
              • e30trooper
                • 11576
                wow , where was that at?
                • IRON-E
                  • 16548
                  I'm having your problems now and changed the rotted fuel lines and it still feels like shit!, I even got a backfire yesterday after the fuel lines were replaced, now I'm looking at a bad fuel pump!!! :(
                  • Wh33lhop
                    • 11705
                    You sure you connected the new lines right?
                    paint sucks
                    • IRON-E
                      • 16548
                      Yeap, it's tripping me out cause I can't find the reason why the car would do this :hitler:
                      • Wh33lhop
                        • 11705
                        How sure? ;) Swap the lines, just to rule it out.
                        paint sucks
                        • IRON-E
                          • 16548
                          Not going to that, only because I followed each line before I could cut the hoses and plug them immediately.
                          Got anything else?
                          • KillaCam
                            • 2103
                            right at the fuel rail.
                            Got anything else?
                            back firing is a bad sign
                            its most of the time timing
                            when the exhaust valve is open and the engine is combusting
