how to change intake manifold gasket M20B25?
  • 2.5-12
    • Jan 2010
    • 1814
    got the gasket, short and seep 12mm 6p sockets, 3/8" u joint and extensions, pizza, liquor, the car
    what I still need figure out where to get and how to apply oil tube gasket, strong magnet, 40+ degree day
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
    • 2.5-12
      • Jan 2010
      • 1814
      so does the thermostat housing need to come off to take the IM off?
      I still cant figure out how that oil tube is supposed to move
      (this is a pic I took of a junkyard car, not mine)
      • 2.5-12
        • Jan 2010
        • 1814
        Originally posted by whatt18yahoo
        holy mother of wow is that pick huge. ok the thermostat housing has to be argued with and massaged but does not have to come off - though it is a good idea. the oil tube has a spring on it so you grab it (like you do your man junk) and push down try to cock it to the side so it stays down as this will make it easier to remove the manifold by yourself.
        yeah, for some reason imageshack left it 14mp instead of reducing
        haha, ok, good - I dont want to buy a new thermostat gasket for 1 month until i do my timing belt and change all that up
        lol @ the man junk part, so push down and twist clockwise or?
        • e30trooper
          • 11576
          make sure to get the new seals for the oil return tube. I didnt and have oil everywhere after i did my head gasket/intake gaskets.. The intake is easy to take off, whats hard is getting that oil return (breather) tueb back in at the same time as lining up the intake on the studs. Good luck
          • catchuk
            • Jan 2008
            • 344
            i just did it tonight, it was my first time removing the m20 intake manifold. It took me about 4 hours. my engine was running rough so I thought Id change them out just in case. Well...... It didnt, oh well maybe its just time for a new afm.
            • 2.5-12
              • Jan 2010
              • 1814
              good place online to order one?
              well, I tracked down my vacuum leak to either this or a leaking injector seal, have a new gasket and I just rebuilt my spare set of injectors with new seals to install as well. Fingers crossed.
              • 2.5-12
                • Jan 2010
                • 1814
                for all your parts needs
                pelicanparts.com - 888-280-7799 talk to javier
                bmpdesign.com - (800) 648-7278 talk to jonathan
                bavauto is usually more money but almost always in stock -and they're a bunch of fuckwit assholes who charge way way way too much 800-535-2002
                although i do love that they have bmw model numbers in their phone number. lol
                oh and nando keeps deleting my posts not me. best of luck to you
                duly noted - thanks much! gotta get the gaskets ordered so I can get going on the first 40+ degree day of the year
                • e30trooper
                  • 11576
                  my car is running super rich now...
                  • 2.5-12
                    • Jan 2010
                    • 1814
                    cant find a part number yet -- still looking for the name of the gasket.
                    • 2.5-12
                      • Jan 2010
                      • 1814
                      I am trying to find it through my local indi first (just like to give the guy business when I can)
                      if he cant find it in the system, I'll call those guys.
                      • 2.5-12
                        • Jan 2010
                        • 1814
                        I started the project today, have some questions.
                        I haven't gotten terribly far today but thats ok, I have taken off:
                        1.) the airbox,
                        2.) the ICV
                        3.) the rubber elbow
                        there are some things I want to know if I should or have to take off,
                        1.) do these hoses need to come off?
                        2.) do these hoses need to come off?
                        3.) TPS electrical connector
                        4.) this nut
                        5.) this nut
                        6.) how do I get to the nut (for the intake manifold) behind a coolant hose or something?
                        7.) this electrical connector
                        8.) the entire thermostat housing
                        9.) the OBC interface block and or bracket
                        10 (not pictured) the dipstick tube?
                        thats all I have for questions at the moment
                        • lcoleman
                          • Jan 2009
                          • 331
                          1, 2, and 3 are attached to the throttle body; it should come loose from the manifold with 4 nuts/washers.
                          4 and 5 are attached to the IM, so they obviously need to come off.
                          Push hose 6 out of the way. Looks like a fuel line.
                          Not sure on 7 and 9, my car doesn't have them. I'd assume they come off pretty easy. 8 can stay. You shouldn't have to open the cooling system at all...#1 are actually coolant hoses going to the throttle body, so set the TB itself aside with those still attached if you can.
                          You're making this way harder than it is. The drain tube is the only difficult part (at least when the engine is out of the car, although I'm assuming it's just tedious to get the nuts with it in). A Bentley manual would really, really help you.
                          • 2.5-12
                            • Jan 2010
                            • 1814
                            Jush finished installing the new intake mani gasket,
                            it turned out to be quite difficult and the order in which you have to do things is very specific (Bentley, Haynes and BMW service manuals were next to no help and rated them as a hard difficulty)
                            turned out:
                            1.) dont need to come off, but can.
                            2.) dont need to come off
                            3.) doesnt need to come off
                            4.) needs to be un done
                            5.) needs to be un done
                            6.) was indeed a fuel line, pushed away, got right to the nut I needed
                            7.) probably doesnt need to be un done but I did.
                            8.) doesnt need to come off
                            9.) doesnt need to come off
                            10.) needs to be un fastened but can remain as-is.
                            I have lots of pictures during the process if I get un lazy enough to put them up here
                            • 2.5-12
                              • Jan 2010
                              • 1814
                              runs so much better with the new gasket
                              still starts a bit rough though
                              whats the fist suspect on taking quite a few cranks before firing? injectors?
                              • bimmer_E30
                                • 5001
                                Originally posted by Dirtbleed
                                you have to take all this off.
                                I bought a brand new thermostat housing and gasket, a throttle body gasket, coolant temp sensor, as well as the intake gaskets, also removed a bunch of plumbing from the cooling system and a new starter. And if your ever gone do a starter it's the right time.
                                can someone post a picture of the coolant temp sensor for the M20B25?
                                i wanna replace mine when i do the tune up but cant find number for the part....:(
                                Originally posted by e30e
