Thanks to your guys' help, I got it all taken care of Wed. afternoon. I ended up pulling the rail up and removing the first 2 injectors (on the forward end of the rail) to pull it up and over the coolant temp sensors.
I replaced the stock 14# injectors with some M50 17# injectors and only replaced the top o-rings. The injectors were supposedly serviced 20k miles ago so I assume the lower o-rings were replaced when the pintle caps were replaced. I did not want to risk breaking the pintle caps so I left the lower o-rings alone.
I put a bit of clean valvoline max-life (might help condition the old lower seals perhaps?, its all i had in the garage anyways so I used it) on the o-rings then put them in the manifold first THEN popped the rail on top. It was hard to trust that they were all on evenly/enough but I put it all back together. It has been about 50 miles and still no signs of leaks. I have the fire extinguisher handy just in case :P these M50 injectors are noisier than the stock ones. I dont imagine the sound will mellow out but no big deal if it doesnt.
