Removing fuel injectors, I'm stuck. 1991 325i
  • Sagaris
    • Sep 2009
    • 2243
    Sorry if the text is hard to read in the pictures.
    I am removing my fuel injectors. I have removed the 4 bolts for the fuel rail. and at this point I am stumped as to how I get the fuel rail out. The plastic rectangular wiring harness loom thing for the injectors is in the way. It almost seems like I can pop the top off of it but I do not want to break it and do not really see how that would benefit me.
    How do I get this thing out of the way?
  • NC325iC
    • Mar 2004
    • 6565
    remove that vacuum crankcase hose then just pull up on it. It comes off easily.
    let me know when you feel dumb.
    • yert315
      • 2734
      there is a round plug under the intake manifold. undo it, wiggle the plastic cover out and you're set.
      • 2.5-12
        • Jan 2010
        • 1814
        there are metal clips that hold both the rail to the injectors and that hold the electricals to the injectors, make sure those are undone
        1991 E30 M3 Brilliant/black - S54B32/5M
        1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
        2011 E82 1M VO/blk/6M
        1991 E31 850i red/grey/6M
        1997 F355 spider red/tan/6M
          • 34839
          you don't have to undo the clips, that's only the early injector harnesses. Just pull up on one end. it'll pop free.
          • u3b3rg33k
            • Jan 2010
            • 2452
            I feel dumb.
            But not as dumb as I would have felt had I shattered 23 year old plastic.
            Ich gehöre nicht zur Baader-Meinhof Gruppe
            Originally posted by Top Gear
            Just imagine waking up and remembering you're Mexican.
            Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
            • Sagaris
              • Sep 2009
              • 2243
              The PCV hose? It feels like the wires are the main issue but I will remove it.
              I remember 2 plugs underneath this guy:
              1 of them is for the impulse sensor, Is the other one for the injectors? It would make sense. It would seem logical that you could disconnect the whole injector loom like that.
              yert315, is that what you are referring to?
                • 34839
                no.. the plug you are looking for is directly under the throttle/intake manifold. that's the diagnostics port. the plugs under it are for the crank and impulse sensors.
                • Sagaris
                  • Sep 2009
                  • 2243
                  thanks for the clarification. I should be good from here on out but just out of curiosity I was wondering if it is easiest to fit the injectors in the fuel rail first, then press them into the manifold, or to press them into the manifold and then put the rail on top of them .
                    • 34839
                    i usually put them into the manifold first.
                    • Sagaris
                      • Sep 2009
                      • 2243
                      That is what I have heard from another person as well
                      • 87-325ic
                        • Apr 2006
                        • 1198
                        sometimes that thing can really be hard to pull out!
                        • NC325iC
                          • Mar 2004
                          • 6565
                          i would think it would be a PITA to get the clips on (that hold the injectors to the rails) if you put them in the manifold first.
                            • 34839
                            nah, they're pretty easy to snap into place.
                            • yert315
                              • 2734
                              I've always found it easiest to put the injectors in the rail first, then press the assembly into the manifold.
                              Either way you do it, be sure that they are completely seated when you re-install. I would get new o-rings for them while you're at it.
