M42 radiator swap complete!
  • Moto-Mucci
    • 2058
    #46
    Anyone notice a rise in coolant temp from the smaller radiator?
    • sohc12vm20
      • Jan 2010
      • 688
      #47
      I like this! My next mod, i'd like to clean up the engine bay like that!
      • Naplm00
        • Nov 2008
        • 1573
        #48
        None, zero, zip! Mine will only run high if the fan is not hooked up. Ill be swapping in the lower temp thermo switch to make it even more efficent
        88 325ic ~~~> Rusty and ugly
        85 E ~~~> RIP
        • ///digitalme
          • Dec 2009
          • 2088
          #49
          um...arent m42 radiators known to explode? why this swap apart from the integrated reservoir??? im going to do the e36 radiator mod on my 318is...
          • Naplm00
            • Nov 2008
            • 1573
            #50
            not that i know of
            85 E ~~~> RIP
            • NC325iC
              • Mar 2004
              • 6565
              #51
              OK, so i have most of what i need and i took the radiator out of the eta today (starting the engine swapping) and noticed that it doesnt have any provisions for mounting this newer style radiator. The old style radiator sits on the bottom of the core support on a few tabs. newerstyle have mounts that come out from the frame or core about half way up the radiator. How have you guys with older cars been doing it?
              • Denny
                • Jan 2010
                • 822
                #52
                bump for answer
                Denny
                ___________
                1990 BMW red 325IC M30B35 all stock Girlfriends ride
                1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                Blogs:
                http://bmw325e30.blogspot.com/ (restoration)
                http://bmw325e30turbo.blogspot.com (Twincharge M20)
                http://bmw325e30m62b44.blogspot.ca/
                • NC325iC
                  • Mar 2004
                  • 6565
                  #53
                  the radiator just sits on the old style mounts, its a little bit shifted to the driver side but its still pretty well centered and at the correct height. Use the new style upper support to hold it in place, i also added a ziptie around the rubber of the upper support through part of the radiator to keep it more secure. as i said its shifted to the side a little so the tabs that are on top of the radiator to engage the upper support arent quit in the right spot so it has some play if you dont secure it somehow.
                  • NC325iC
                    • Mar 2004
                    • 6565
                    #54
                    Originally posted by Naplm00
                    top one is a stock hose for an eta
                    bottom one is a touring car hose WITH AC...if it was a 11531722216..it would be WITHOUT Ac
                    i can tell you that the stock eta hose does not fit
                    edit: Lev any way you can double check that hose? please?
                    • einstein57
                      • Jun 2007
                      • 10780
                      #55
                      Take the rubber mounts off and cut out a chunk so you can center it. Also make sure you have a good tranny stop cause the pulley will eat in to the drain plug.
                      ru
                      I just used a lower m20 hose. just cut to fit. Works great and cheaper then a touring hose. If their is a large enough demand i can make an m20 specific upper radiator hose made of 3-4 ply silicone. Price would be about $50.
                      www.gecoils.com
                      • NC325iC
                        • Mar 2004
                        • 6565
                        #56
                        a lower m20 hose?
                        • einstein57
                          • Jun 2007
                          • 10780
                          #57
                          yup
                          www.gecoils.com
                          • browntown
                            • Jun 2004
                            • 3524
                            #58
                            I'm still holding out hope that a m30 mounted far enough back without the mechanical fan will allow a m42 rad or some other integrated overflow tank radiator./
                            • NC325iC
                              • Mar 2004
                              • 6565
                              #59
                              What is everyone doing to keep the ps pump off the drain plug? Mine might fit a sheet of paper btw them, I have another ps pump with a smaller pulley center on it but I donno if it works.
                              • NC325iC
                                • Mar 2004
                                • 6565
                                #60
                                A lower m20 hose is about 4 inches long and connects to a metal pipe
