M42 radiator swap complete!
  • Ginger_e30
    • Jun 2014
    • 8
    #76
    What about the transmission cooler lines that ran to the m20 radiator? The radiator I found has a tranny cooler on the front but the connections are different that's the m20 ones what do I need to do!?
    • Pocket Chant
      • Mar 2012
      • 403
      #77
      1987 325is, S50B30US, Kamei side skirts, Zender Spoiler.
      MT2 Wheel, 95 M3 Rack, Condor Speed Shop knob, UUC SSK w/ DSSR, Billy Sports/GE Coilovers, KAMotors CAI.
      Originally posted by MclubSport
      Why you have a badge on wheel ? You do not know what car you have? But if you have a mustache, you know better where is your mouth?
      Horrible with responding to PMs, I'm so sorry.
      • cdeason7
        • May 2016
        • 38
        #78
        Bringing back an old thread, I was thinking of doing this to clean up the engine bay but I want to know if someone has solved the power steering nut issue, thanks
        • Supratreo
          • Aug 2016
          • 135
          #79
          Quick question for you guys.
          I'm going to run the stock fan, do I still need to get the temp. Switch?
          Any clarification would be great. Thanks
          BTW, I'm doing a 89 b25 swap on a 87 ETA.
          • Supratreo
            • Aug 2016
            • 135
            #80
            Well, got it mostly sorted out today but 2 quick questions.
            This is going in 87 e to I swap, I got all of recomended parts minus the electric fan and temp switch.
            I was trying to figure out how to install the buffer cup PN 17111712347 but just can't seem to figure it out. The car has 4 mounting point welded to the radiator support, 2 of which are being used. I can't see where that buffer cup would go but the radiator seems to sit very well on the 2 existing mounts. Do I just use those?
            Also, the top has bout 1/4" of play, is that normal? I don't want it to hit the fan or the drain plug to hit the PS pump because it's VERY close.
            Thanks
            • potatomash
              • Nov 2014
              • 203
              #81
              Generally its loose in factory mounts. Push the drivers side one up from underneath and itl pop out of its slot and you can put the new one in its place.
              Thanks
              T U R B O - M 2 0 - B U I L D
              M U S C C O O
              • Supratreo
                • Aug 2016
                • 135
                #82
                thanks for the reply. that was the plan but BMW ordered the wrong part so we made it work. with all of the hoses connected and some packing on the top mounts it is very secure. we also chopped up the original fan shroud and made it work with the m20 fan. well try to get some pics up soon.
                • spiDmang
                  • 3941
                  #83
                  super helpful, thanks guys
                  91' 318iS - S54/6MT Swapped
                  08' E90 M3 6MT - Daily
                  Originally posted by IronJoe
                  Originally posted by 2mAn
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4516
                    #84
                    Does anyone have an updated upper coolant hose they used for this? 11531722217 is NLA.
