rod bearing replacement question's?
    Originally posted by custom e30 View Post
    im all set to replace rod bearing and swap original head back in, is that a waste of time now
    prob that will be what is need, but its hard to tell until you open up the engine
    1989 cirrisblau-metallic 325i
      im doing it tomorrow and i will up date,
        first of all you shouldn't be trying to start it. sounds like there is more issues than a rod bearing, i would pull the motor and inspect the bottom end carefully. i highly recommend taking it to someone who knows what they are doing.
        '12 F30 328i Sport Line
        '91 SpecE30 #523
        '00 Ford F-350 Dually Tow Vehicle
        BMWCCA #360858 NASA #
        128290
          no resources, so im just gonna go for it and hope for the best
            yea id advise you pull your head off look for broken stuff inside, then go buy a used motor and do nothing but put it in your car dont open it up, find one with less then 200k on it and you probaby wont do anything to it for quite a while
            Shawn @ Bimmerbuddies
            Bimmerbuddies LLC
            717-388-1256
            2971a Roundtop Rd, Middletown PA 17057
            bimmerbuddiesllc@gmail.com
              i would just stop and do some thinking first. its obvious you arent paying attention to these fine people, either that or you dont understand what they are saying.
                stop asking questions if you are not going to listen.
                  Pull oil pan and check con rods, spun rod bearing....Stop guessing check compression on each cylinder
                  Good luck
                    well i needed a head -edit-, it was my first time -edit- and i learned the hard way -edit- and not to forget to time the head. -edit- when i tightened head down it bent -edit- and broke. I paid 50 bucks for head out of the yard -not edited-, im about to fix head -edit- after i fix -edit-
                    dood start over, sell me your good m20b25 head, ill buy a new rocker and valve. and you can go honnnnnnnnnnnddddaa-a-aa-a-a-a
                    sorry to be brash, you snapped your timing belt on a interference engine, blew it to shit, then tried cranking it...no good,, thats whats this snap pop bullshit sounds like..
                    You need to not try and fix yourself, or get a set of telescoping gauges, micrometer, do cylinder out of round, taper, etc., check mains, big ends, connecting rod straightness, length, width, pistons, valve seats, etc..
                    I'm boring myself... you put wong head mista mista
                    marbles? ps. m20 no have roller bearing inside engine... weirdo
                      so i pulled my head off and theres no damage to pistons or head, thank god, and i did not snap my timing, so will go ahead with 2.5 head repair and replacement, then do rod bearings, thanks to everyone for the help
                        i have my engine ready to pull, i ordered my rod bearings and crank bearing and for $150.00 i found a import shop that will replace rod and main bearing the correct way and balance, very excited...
