Hey guys, I recently wrecked my e30, uknowingly I knocked my oil cooler loose and it started leaking oil. I drove the car not knowing wut was going on and I think I blew up the engine cuz I opened up the oil cap and smoke was coming out. Now my question is what parts will I need to rebuild a blown motor. (keep in mind that I plan on running a t3/t4 turbo set up eventually. I appreciate any help, thanx.
M20B25 Rebuild, HELP!!!
Tags: None
low compression pistons, new rings, have the head surfaced, re-do the valves, rockers, etc. pm me for any more questions or help1990 Alpinweiss 325i - secret 500whp buildOriginally posted by audiquattrotbimmers b4 b*tches....remember that.
2000 Audi S4 B5 Laser Red
1990 Nissan 240sx - Drift Missile
2006 CBR600RR
If you ran the engine for any period with no oil pressure, a full engine tear down and measurement of all wear surfaces is required. If you are lucky, the crank and block survived. The head and pistons probably didn't. The path of least resistance if there is significant damage will be a replacement engine.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
