Hey all,
I have owned several e36 M3's and currently DD a 330i 6speed. I talked the wife into letting me get a project car. So I bought an 1987 325is (not running).
I have been trying to get the M20 in there working before I go any further with this. If I can get it working, great I will keep it and probably turbo and have fun. If I cant, I will go with a swap right away.
I can not get the engine to start as of now. It turns over and over but no fire. I have tested the following (after much searching):
Battery - Seems strong, tuns very well. At any rate, Its hooked up to a speed charger so even if its weak, it shouldnt matter.
Fusable link - intact
CPS - 497ohms
Temp Sensor - 4k ohms (I have it jumpered with a 2.2kohm resistor for troubleshooting purposes)
Injectors - all 6 are 16.2-16.4 ohms
Spark - all 6 wires gave me very large (1/4-1/2 inch) sparks when I gave them the screw-driver to the intake manifold test.
Spark Plugs - Brand new, OEM, correctly gaped.
Fuel Pressure - 43psi at fuel rail
Fuel pump - see above
Relays - Appear to be working...When I crank, I can hear injector clicks. I have tried cranking with the fuel relay in and with it jumped with no different result.
I have not checked the grounds because I tested the spark plugs to the intake manifold with no problem. I have not taken apart the humming thing on top of the intake (i forgot its name) because its humming as intended, and I dont see how it would keep it from starting. I have checked for air leaks as best as I could with it not running. I have not checked the computer because it sounded like it was working.
I did run a compression test...the results worry me a bit, I dont want to spend a penny on this motor until I can get some opinions...Keep in mind these were taken with a cold motor. I have not tried the oil trick though.
1-87.5
2-85
3-85
4-87.5
5-85
6-82.5
Whats everyone think? New motor or can I get this one to live with out a rebuild?
-Chris
edit - timing belt is intact.
CPS - 497ohms
1-87.5
2-85
3-85
4-87.5
5-85
6-82.5
-Chris
