Help!
  • yayforbrandon
    • 86
    Help!
    how can i get power out of my 325e?
    - i have done an exhaust and intake.
    - springs and shocks.
    but the thing is slow as balls.
    i was gonna do an i motor swap but someone told me you need everything like wiring harness,ecu, and a shit ton of sensors.
    i really need some help with that^^^
    but if anyone can inform me then i will be thankful.
    -brandon
  • jeffw
    • 1087
    chip your ecu. makes a difference
    • yayforbrandon
      • 86
      well my motor went so. i was wondering what i could do. I was gonna buy an i motor from DTM and swap it. but i need to know what needs to be done before i do that. i might just do another eta motor but i really dont wanna do that. So i was doing some reading and just found all you need is a wiring harness connector and then splice them together and it should be good to go? but im not an expert on this kind of stuff so i could really use some help.
      -brandon
        To swap to an M20B25 engine you'll need a complete engine, engine wiring harness, DME, and AFM. Depending on what year car you have some splicing of the wiring for the C101 connector may be required.
        • jeffw
          • 1087
          if you have an early model i believe you can just get a early model harness and with a few little changes its good to go. I've done a few swaps with dashboardmonkey and they arent that bad at all. However if you have a round plug it super simple you just have to run two wires to the ecu. its quite simple really. and worth it. good luck
          • yayforbrandon
            • 86
            is there a write up??? cause i get what you mean but dont know which wires and stuff. and yeah i have an 87 325e that im putting a 325i motor into. the guys at DTM said its a direct match
            • hotballs
              • 1155
              Where is DTM and how much do you plan to give them for an m20?
              • yayforbrandon
                • 86
                its in oceanside. and they are gonna give me one for 350ish
                • jeffw
                  • 1087
                  87 is a round c101 and it is a plug and play swap. super simple
                    An M20B25 swap into an 87 will be plug & play only if the new wiring harness is from a car built between 9/86 and 8/87. Otherwise slight mods to the harness will be required.
                    • yayforbrandon
                      • 86
                      thank you guys so much. haha i have needed this. i shall update with pictures and everything of the swap when i start :]
                        • 37833
                        Neil at DTM is a great guy and knows a ton about E30s. Talk to him if you haven't already.
                        Grover Beach, California
                        BimmerHeads.com
                        • yayforbrandon
                          • 86
                          I have to talk to him and jake about the swap and they are really helping me out as you all did on here. once again thanks
                          • yayforbrandon
                            • 86
                            going to pick my motor up today :] aha
