Just pulled my intake, throttle body, thermostat housing.
Replacing the gasket and all the hoses, vacuum and coolant with the kit from BavAuto. Also replacing the thermostat housing, thermosat and both coolant sensors.
While I have the fuel rail out, sending the injectors to be cleaned flow matched, new orings. Maybe just new injectors. Any input from anyone on this? New fuel line and return fuel line.
- Thinking of hot tanking the intake and throttle body to get them squeeky clean then powder coating them, black I think.
- While Im at it, and I have a t belt and WP sitting in the garage.
- Thinking Ill tear into that side of the engine as well.
WPT-Belt and tensioner. - I also have crank seal and cam shaft seal on hand.Also have a set of belts that will go on.
- Spark plugs, dis cap, rotor, and new set of wires ought to go well with all this R and R.
- Guess I will hot tank and powder coat the valve cover, of course, new gasket there as well.
Ok guys, what else? I dont want to go this deep again on this car. What else can I do while Im this torn down? Should I go ahead and just pull the head and do valve springs and guides or what?
Input is appreciated. BTW Im in NO hurry to complete this job. Well.. 3-4 months tops as IM moving then.
Please chime in. JLevie.. your thoughts most appreciated Sir.
Thanks in advance.
