I've got a b27 that's in good condition but could use a little freshening up.
I'm debating whether or not to pull the head and bring it to the shop for some head work (valve seals, decking, etc.) and install an i cam while I replace rings, bearings and seals or to just dump the whole motor and swap in an entire i motor/harness/injectors/etc.
Pulling the existing head and putting in the i cam is easier than an entire motor swap. I've got enough budget to have the head work done, or do the i motor, but not both.
My thoughts are that a reliable 2.7 with the i cam and a good chip is almost as strong - but way more reliable - than a junk yard u-pull.
Is this completely stupid or is pulling the i motor worth the extra hassle of sourcing the harness and dme?
