my E30 suddenly won't start! I'm stranded!
    If its not even cranking
    The wiring @ the C101 is bad
    The Starter is dead / dying / on its way out
    I would look for +12V @ the solenoid to verify the key is getting to starter.
    As far as the bolts go, one from the top, one from the bottom. Two person job.
    You may need to vice grip that bottom bolt.
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
      Originally posted by E30SPDFRK View Post
      Get it from underneath the car. Stick a wrench on it then go back to the top and loosen the nut.
      great other than the fact there is 0 chance of getting a wrench or socket on the back nut. automatic trans line is in the way.
      1991 E30 M3 Brilliant/black - S54B32/5M
      1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
      2011 E82 1M VO/blk/6M
      1991 E31 850i red/grey/6M
      1997 F355 spider red/tan/6M
        no solenoid noise or starter noise at all, I dunno what C101 is.
        ordered a new starter, cant get the current one out. the bolt head is not reachable no matter what I try to get at it with. I swear there is no way to get this off.
          is the bolt head on the back a Torx T-12? can I use a 10mm 6-pt socket on it to hold it still?
          still having a hard time getting a socket up there
            you need an extra pair of hands for this. get a long extension, probably 22inch. universal at the end of it. then have a buddy reach in and put a wrench on the bolt from the top. use said super extension to get to the bolt from the bottom on the other side. turn until loose. its tough, but it can be done. i had a lift and two helpers when changing my clutch and it still took me 2 hours to get these bolts.
              when you do get them out, tap the starter housing to the same thread pitch as the bolts so that you can just use two bolts and bolt them directly into the starter housing from the trans tunnel. no more reaching up the arse of the m20 and trying to fit a wrench anywhere. Just lots of extensions blah blah
                starter turned out to be ok, I have to figure out, now, how I can start the car jumping the solenoid 12V trigger to the battery but I can't start it with the key.
