Peake fault code 16 idle speed actuator (close)
  • formula driver
    • 2263
    I got this code with the peake code reader.
    My question is, what is idle speed acuator(cloe)? What things should I check. I would think the ICV, or the TPS but Ive checked them both, though I could have messed up when I was checking the TPS. But Im pretty sure the ICV is good as it buzz'z.
    From reading up a bit, Ive gathered that I can get that code if the car stalls from a bad idle, so thats pretty broad. Thanks for any help, this is my first time using this tool.
    Clear the code (disconnect the battery for 30 seconds) and see it it re-occurs when the engine hasn't stalled. If it does, either the ICV is bad or there's a problem in the engine wiring harness.
    • formula driver
      • 2263
      Ok...
      I cleared the codes, than pulled the new ones.
      No codes AT ALL. I can start it and it stalls immidiatly, I can keep it running with a bit of throttle but it revs faster than Im actually opening the TB. The ICV buzz's and even vibrates a bit.
      But after I started the car and it stalled, it threw code 16 again. idle speed actuator (closed)
      • formula driver
        • 2263
        I just took the ICV out and cleaned it, I believe it to be a good unit.
        But interstingly enough, I unplugged the AFM and the car would run and idle, it wouldnt run very smootly but it would run.
        Anybody have any idea what my problem could be? Thanks
          Intake leaks... Have a smoke test run.
          • formula driver
            • 2263
            Do you know what your talking about? Or are you just saying what comes to mind?
            Sorry for being a dick, I just hate misinformation.
            • txtorquemade
              • 1758
              HOW many posts do you have on here? and you ask JLevie a question like that?!!!
              Im thinking... do you know what YOUR doing?? or saying...
              Kinda laffin my ass off too, but you really ought to pay attention to who inputs the most reliable information and those that tend to pop off BS. If I say it...well.. it wont be total BS but I can be wrong.
              If JLevie says it, I would take it as fairly authoritative and reliable.
              sigpic 1987 325is
              • formula driver
                • 2263
                well...
                If you look jackass, Ive been here since 03. WTF does a post count mean?
                Ive rebuilt a few m20's along with swapping a BUNCH more. So yea, I think I know what Im doing. I asked because he said 2 completely different things.
                Now Im pissed cuz your stupid ass bumped my thread with NO info at all. Man you suck...
                Im also quite sure you know how hard it is to sift through bullshit on the internet. Go play in traffic.
                • e30Matt
                  • 5077
                  Make sure the idle switch is closing on the TPS, otherwise the ICV won't know to open up and let air through to control the idle speed. You should hear a small click when you move the throttle off the stop, and a second click at full open when the WOT switch closes.
                  • formula driver
                    • 2263
                    Thanks Matt...
                    next time I get around to working on it, Im taking the entire intake side back apart. Checking the harness to the injectors, checking the TPS, checking for intake leaks, and a bunch of other stuff. I have a feeling I have a few different problems...
                    • CR325IS
                      • 514
                      Im sorry I have a similar problem and took apart my ICV, MAF, and intake boot to check for leaks/functions correctly, and I found nothing before I installed my after market chip my car idled fine...so my mechanic told me to replace the chip with the original. I havent done this yet but he also told me to tighten the throttle .5 turn to see if that helps with my surging idle I have when in drive at stop signs/lights. I dont know what a TPS is or where its located so could some1 point me in the right direction before I take my ecu out and accept a faulty chip. Thanks
                      • formula driver
                        • 2263
                        Its located under the T-body, held on by 2 Philips head screws. Has a wiring harness ran to it, you cant miss it.
                          • 34847
                          well...
                          hey, rip anyone off lately?
                          • StereoInstaller1
                            GAS
                            • 22679
                            well...
                            1. You have no room to be a dick, so calm your ass down.
                            2. He DID see your post count, that is why he was wondering why you were being disrespectful to JLevie, the man knows his shit and we all would expect someone who has been here as long as you to know that.
                            3. Post count means you have been involved, even if you are a jackass.
                            How about a quick apology to one of the very few members who actually go out of their way to help newbies AND "experienced" guys like youself...seem like a good idea?
                            If not, don't let the door hit you in the ass.
                            Closing SOON!
                            Thanks for 10 years of fun!
                            • formula driver
                              • 2263
                              Nando, I always thought you were a cool cat.
                              get some new material bro. And your answer would be no.
