323 top to a 325e bottom
  • unkown
    • Mar 2008
    • 83
    i have a 323 top end. can i bolt it directly to my 86 e, when i change my timing belt/water pump. I bought a complete top end seal and gasket set,and torx bolts, spark plug wire set, cap,rotor,fuel filters, motor mounts and a couple other odds and ends.
    1.will it go on
    2.will it work
    3.do i need to change the ecu, can i use the 325e until i find a better one.
    where can i get the seal for between the master cylinder and the break booster
  • BimmerScreamer
    • Dec 2008
    • 413
    by 323 top do you mean a 731 head?
    Anything can be done
    • unkown
      • Mar 2008
      • 83
      yes, everything above the head gasket
      • unkown
        • Mar 2008
        • 83
        so....nobody has an answer??? ive read alot (lots and lots on this) but i havnt read if i can do this...im looking for a yes or a no, maybe not that simple but something close
        thanks for the help.
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          yeah you can
          but to fully enjoy it you ned to switch to "i" engine management.
          the injectors are of a different resistance too (ohm)
          -Andy
          • Quadrajet
            • Jul 2008
            • 1278
            Did you buy that head that was for sale at NW European autoworks in Bellingham?
            • unkown
              • Mar 2008
              • 83
              thanks andy. the 731 head came off of a 323 i had 3 years ago. it was rebuilt 20k miles ago. it had a automatic in it, i also own a 86 es, the tranny went out 323. the es needs a timing belt....
              • unkown
                • Mar 2008
                • 83
                so can i put the e's f.i.'s in the 323 top and be good to go until i get the e.m. and f.i.'s??
                • 2.5-12
                  • Jan 2010
                  • 1814
                  it'll run like that, yeah. you'll probably be down on power until you swap it to motronic 1.1 or 1.3 though.
                  1991 E30 M3 Brilliant/black - S54B32/5M
                  1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
                  2011 E82 1M VO/blk/6M
                  1991 E31 850i red/grey/6M
                  1997 F355 spider red/tan/6M
                  • RainierHooker
                    • Jul 2009
                    • 2026
                    Linkies for your reading pleasure:
                    I'm doing the same thing right now, but am debating the upgrade to Motronic 1.3.
                    Hartge did basicly this same setup in some of their early e30's. From what I've read they pretty much just used their own cam in the m20b23 head. I'm sure you could easily replicate the power of these cars with a chip, and possably stronger injectors, along with your Motronic 1.0 although the bennefits of 1.1/1.3 aren't something to scoff at. The next major step would be a differential change. I'm going with a 3.25 LSD, but a 3.46 or even a 3.73 would work just fine, although the 3.73 might be a little too tall without the 1.1/1.3 conversion.
                    1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
                    • unkown
                      • Mar 2008
                      • 83
                      nice, ill start taking it a part and look for a new ecu and harness tomarrow!!
                      thanks for the info and help
                      • 2.5-12
                        • Jan 2010
                        • 1814
                        Originally posted by unkown
                        nice, ill start taking it a part and look for a new ecu and harness tomorrow!!
                        Fixed for ya ;)
                        • hotballs
                          • 1155
                          You had an automatic grey market euro 323i? That's pretty rare.
                          Tear the head down and use dual valve springs if you want to rev over 5500. Without 1.3 motronic and a higher read line you won't be utilizing any of the heads properties, which is just a 200 head with a hot cam and bigger inlets.
                          • unkown
                            • Mar 2008
                            • 83
                            the top end was rebuilt, the car was deemed a gross pollutor by the state of california. rare car,but all the after market emission controls were junk, cat,charcal canister, o2,and the impossible to find ecu for the car, the one that was in it was not a bmw, some 80s electonics company in santa barbra it was broke. the interior was f`d up.when the tranny went out (3 years ago)i parked it....broken tree branch(that fell on it)was the last nail in the coffin. to much work...
                            • unkown
                              • Mar 2008
                              • 83
                              well the top end rebuild is done, the main problem was the cam shaft was f***ed. so i put the e's cam in the 731 and used the 323s manifold (larger openings). now it smells like its running a little rich in oxygen ! should i put the e's manifold back on? dose any one think this would help, or could it be something else.
                              also i have a little white smoke, could be from me cleaning the motor and getting water in the down pipe. i let it idle and drove it around a little, to hopefully dry it out (no luck). when I'm driving there is hesitation when i step on the gas.
