Vac leak under the TB/intake -> erratic idle?
  • ortholithiation
    • Dec 2009
    • 181
    87 325is
    Car was a bit rich when I bought it. Multiple PO’s I no idea what has been messed around with. I don’t think this afm has an adjustment screw on it.
    Runs rich a bit still, erratic idle 800-1500 for the first 30 seconds, then runs steadish at 1K. (note just had the battery disconnected and reconnected) and this was when cold. But otherwise starts fine.
    New plugs- check and gapped at 0.28
    Plug wires and coil- check
    Distributor- not checked yet
    Fixed leaky fuel line
    Fuel pressure within spec- check
    IAC valve- cleaned and resistance checks out
    AFM- cleaned out, checked for binding and resistance increases- check
    Intake boot- check looks new
    Vac lines to IAC, emission- check, tend to pop out of the TB a bit, so a little rtv was applied, but appear okay.
    Haven’t checked the TPS yet, but I hear what sounds like a vac leak coming underneath the TB and intake manifold at idle. Hard to tell from because of the K&N filter and injector noise.
    Is this a common problem? I think the breather tube is underneath there as well? Engine seems to rev okay, but running way rich. Also a healthy amount of oil coating all of the intake parts? I’m used to it on a turbo car but on NA?
    Going to get some dry ice and fab up a smoke machine, but looking for other suggestions to trouble shoot.
  • 2.5-12
    • Jan 2010
    • 1814
    here's what mine sounded like with a bad IM gasket: http://www.youtube.com/watch?v=JRocSAnE9Cs
    heres what it sounded like after:http://www.youtube.com/watch?v=wDgrhw3sQSM
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
    • ortholithiation
      • Dec 2009
      • 181
      mines not that bad.
        • 34839
        it's not a breather tube, it's an oil drain from the head to the block. but vac leaks there can cause all sorts of strange problems.
        • 2.5-12
          • Jan 2010
          • 1814
          Originally posted by nando
          http://www.r3vlimited.com/board/showthread.php?t=165760
          on my M20 the oil return passage is in the intake manifold but has nothing to do with the air intake system.
          • SpecM
            • Oct 2005
            • 4531
            it kind does, a leak here can cause a vaccum leak
            1989 cirrisblau-metallic 325i
            • 2.5-12
              • Jan 2010
              • 1814
              only if the gasket is bad between the oil return and the intake, they are separate, if you hear a leak, its from somewhere else.
              I have a picture of a M20B25 IM somewhere I can show you if you need clarification
              • SpecM
                • Oct 2005
                • 4531
                thanks but I don't need a picture, I've taken my intake manifold off before, more times than you have... without the need of post a thread for help, I might add.
                the tube is supposed to be under vaccum, from the head, from the breather that runs to the valve cover to the throttle body.
                • 2.5-12
                  • Jan 2010
                  • 1814
                  just because I wanted to make sure I was going to take it off correctly and have only done it twice doesn't mean I haven't paid attention to how it is laid out. That being said, I did forget that that tube was under vacuum like the top end it is connected to.
                  I still bet IM gasket on his car though
                  • agent
                    Vice Grand Pubaa
                    • 7960
                    FWIW, replacing this hose resolved a warm idle issue for me recently.
                    Originally posted by kronus
                      • 34839
                      I know it's not part of the intake air, I said that in my post. it can still cause an oily intake problem.
