Couple issues..
  • noE30
    • Jun 2008
    • 2260
    Couple issues..
    I searched and couldn't find anything similar to my issues.
    Some times my car will take about 6 secs to start, it doesn't matter if the car is warm or cold either. I can hear it turning over when I turn the key but it sounds like it just doesn't want to start. I just replaced all the gaskets, spark plugs (new oem copper ones), new dist. cap/ rotor, fuel filter, coolant temp sensors (gauge and computer), and complete valve job (new seals/ valve grind/ valve adjustment). Any ideas on what it could be?
    I've also got a random idle issue too, I say random because some times it acts up some times it doesn't. When I start the car sometimes the idle shoots to 2k and just sits there for a few min and slowly comes down after a few min.(doesn't matter if cold or warm). When my idle isn't at 2k, it usually sits at around 600 which seems low. When it idles at 600 the engine shakes alot and actually vibrates the car, feels like its going to die.
    Once the engine has started it runs perfectly fine though. Any help will be appreciated thanks.
    Flickr
    @michael.colby on Instagram
    "All he needed was a wheel in his hand and four on the road"
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    check for vacuum leaks
    check the main relay too
    -Andy
    • txtorquemade
      • 1758
      Smoke test for vacuum leaks.
      O2 sensor
      Main relay
      Fuel pump relay
      Battery
      sigpic 1987 325is
      • llll1l1ll
        • 782
        Shaky motor while idling could possibly be your motor mounts.
        However, I'd check your vacuum leaks first.
        Me: "I can't wait to redline my car!"
        Mark: "Didn't you just break a rocker arm?"
        Me: "Yeah, I don't think I've learned my lesson."
        Mark: "You never will."
        • Cyrix2k
          • 593
          I'm going to echo the "check for vacuum leaks" suggestion.
          1997 540i/6 - stock
          1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
          1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
          • lennon
            • Jun 2008
            • 1416
            sounds like vacuum leak(s) to me. on a side note, my car idles naturally at about 600, thats a normal m20 idle.
            • hotballs
              • 1155
              I don't think the words 'normal' 'idle' and 'm20' have ever been said in the same sentence.
              • 2.5-12
                • Jan 2010
                • 1814
                Originally posted by hotballs
                i don't think the words 'normal' 'idle' and 'm20' have ever been said in the same sentence.
                +1 :)
                1991 E30 M3 Brilliant/black - S54B32/5M
                1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
                2011 E82 1M VO/blk/6M
                1991 E31 850i red/grey/6M
                1997 F355 spider red/tan/6M
                • noE30
                  • Jun 2008
                  • 2260
                  This might be a dumb question but how what is a smoke test? and how do I do it? Also what needs to be checked on the relays?
                  Flickr
                  • 2.5-12
                    • Jan 2010
                    • 1814
                    basically a shop hooks a machine up to your intake and it pushes smoke into it, wherever smoke comes out, you have an intake leak.
                    • noE30
                      • Jun 2008
                      • 2260
                      What needs to be checked on the relays? Im terrible with electronics but ive got a buddy who should be able to help me if needed.
                      Flickr
