I have a 1988 325ic automatic. I purchased it with a blown motor and quickly purchased a motor from a 1989 325is 5 speed. A local (non BMW) mechanic did the swap for me. The engine ran ok for about 1 hour, thereafter, it will start but cut off as soon as i put it in gear and try to take off. The car literally breathes.....the idle goes up and down. Local mechanic says bring it back, its probably the throttle position sensor. Others that i have talked to say its the idle control valve. Im not confident in the local mechanic. At this point i want someone with BMW experience.
I noticed that nothing is plugged into the thermostat temperature sensor. Local mechanic says it doesn't need it. I also noticed that the TPS is for a standard (5speed) car. Mine is an automatic. Is there a difference? I need some sound, experienced advice.
Ismael
Ismael
