What chip(s) will work with a 2.7 SETA bottom and an "i" head?
  • phenryiv1
    • Jul 2009
    • 3246
    Are there any chips that are shown to work better than others for a SuperEta-based 327i build? I have a 1988 M20B27 bottom end and the 885 head from a 325i.
    I see a lot of chips that will raise the rev limit and open up the M20B25, btu I don't come up with much for the Super eta with the i head.
    I have 19 lb./hr injectors, as well. I have the stock "i" 14 lb. ones available, but I'd rather go up to the 19s.
    TIA
    Patrick Henry
  • Mike
    • 932
    Yeah, Im interested in what you come up with, I'm running stock 173ecu with stock maps, but got a split second MAF conversion that really straightened things up on my b28. I still want the car tuned professionally though...
    Supatek -noun - your basic know it all
    • E30Kaiser
      • Mar 2008
      • 1790
      I am running a similar setup, with M30 AFM and injectors. Would really like to know what my options are for chips.
      "We're not here for a long time, we're here for a good time"-Colin McCrae
      • phenryiv1
        • Jul 2009
        • 3246
        Here I get all excited in thinking that I have 2 suggestions...
        Well, gentlemen, it appears that we wait for an expert to chime in...
        Patrick Henry
        • phenryiv1
          • Jul 2009
          • 3246
          Did you go straight to the M30 AFM, or did you run the B25 one for a while? My local JY has an M30 with an AFM that I could get for cheap. Does it use the stock B25 intake boot? Is it a direct bolt-on at the I'm side, or does it need an adapter?
          Also, what size are your injectors, 17.5 or 19?
          (It is my thread, so technically it isn't thread-jacking!)
          Patrick Henry
            • 34844
            there isn't going to be an off the shelf chip for any 2.7i
            but it doesn't matter that much, if you have a working O2, and a 2.5 chip for the injectors you're using, it will run just fine.
            • E30Kaiser
              • Mar 2008
              • 1790
              I went straight to it, because I bought the car with all of this done to it, but I think it is a direct bolt-on or it might need an adapter as I know the M30 AFM is 3 inches on the filter side and I believe the M20 is around 2.5, not sure what it is on the manifold side honestly so I can't tell you. M30 injectors I want to say are 19lb.
