first rev is in car second rev is outside of the car, was inside my garage
anyone know what is is?
When i did the valves I set it to sort of have a slight feel of paper dragging against paper at .01" then i tried putting in a .012" to make sure that it was tight enough, if the .012" didnt fit in i called it a day for that valve. When i had it tighter( i had it feeling tight at .01 and didnt try to fit a .012" the first time) it was MUCH louder.
ATM im using 20w-50 gtx 2, ill check the oil level actually and ill have a look at how gritty it is. It was running with a blocked FPR before so the oil was a bit diluted (i did an oil change once i fixed the FPR).
could it be knock? i heard the paintball sound once on a hot day up a hill with 91 octane (lowest one here) so ive been using 98. the dizzy is fully wound advanced.
I also tried having the car in gear and just turning the car off and id still get the rattling noise.
And how often should i change spark plugs?
