Rough Running + High Fuel Consumption = FPR??
  • tcyoung2
    • Jun 2010
    • 1
    I have an 89 325is in which I just replaced the head. I've put about 150 miles on her since her reassemble. Problems:
    1. Runs rough - seems to stumble through acceleration
    2. Won't rev past 4000k. At several points while driving her, she wouldn't rev past 3-4k. At one point she didn't even rev past 1500 and I had to pull over. Once I let he rest for a few seconds she was okay.
    3. High fuel consumption - I burned nearly a full tank of gas to go 150 miles.
    4. Started her up yesterday and had some smoke coming out of the exhaust. After about 15-20 seconds it stopped and normal exhaust was emitted. I also noticed a slight amount of exhaust exiting around the number 6 cylinder exhaust port.
    I initially believed that it could be a problem in the ignition system. Results from my check:
    Coil:
    Primary Resistance: 0.8ohms
    Secondary Resistance: 5910 ohms
    Wires: (checked from their corresponding contact inside the cap to their end which connects to the spark plug)
    6070, 6160, 6030, 5850, 6060, 6120 ohms
    Coil wire: 1990 ohms
    Rotor button: 1270 ohms
    According to the bentley, the coil and the wires may need to be replaced. I doubt that they are worn out enough to cause such a problem with the car though.
    Let me know your thoughts and suggestions. Thanks!
    Check the rail fuel pressure and pull the top timing cover of and check cam timing.
    • e30Matt
      • 5077
      What color smoke was coming out of the exhaust? I'm with Jim on double checking cam timing, sounds like it may be a tooth off.
      • accident
        • 7303
        +1 for cam timing.
        also: your car is a machine. it does not have a fucking gender.
        Moral of this story?
        • E30Gus
          • Jun 2008
          • 781
          Originally posted by accident
          +1 for cam timing.
          Unless you child names your car; then you just go with it. :roll:
