Does anyone know how to get the signal from a 1.3 DME to the tach on a older E chassis?
85e to 89 2.7i tachometer
Search for a thread by dashboardmonkey. Had the same problem and he helped me through it. There is a connector, forgot what it's called, that is in the dash near the ECU that leads to the tachometer and fuel economy guage. You need to run a new wire from the main engine harness in the engine bay to the connector in the dash.
Look up the wiring diagram for your chassis here http://www.armchair.mb.ca/~dave/BMW/, and the diagram from the donor engine. Connect the dots.Comment
