I'm leaking a lot of coolant out of the back of my engine block. it seems to be coming from a bolt on the back of the head, next to the fire wall. can any body elaborate more on whats leaking, and what i can do to fix it.... i can't seem to tighten the bolt any more.
help. leaking coolent from back of block. not heater core...
Tags: None
If this an M20 engine, the leak is either from the heater hose fitting on the rear of the head or from a failed head gasket. Of those the heater hose fitting is the more likely. You'll need to remove that fitting, check to see if it is still good, and re-install it with a new gasket.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
Ok. i'll do some more poking around, but it really seemed like it was leak from one the the 3 bolts on the back of the head. But i agree. my car has 120k miles on it, i can't see it been the head gasket.
Just for the record though, does any one know what those 3 bolts are for?Comment
ok, can any tell me if theirs a trick to getting the intake manifold off? whats the deal with that weird brace right about the engine mount?
I didn't want to make a new thread for such a simple question.Comment
i got the issue figured out.... my actual probelm was that i had left a bolt on the manifold lol it was in plane few tooComment
