I'm thinking about checking out a 325i w/ a stroker E bottom I top end iirc. Says it runs/drives but he hasn't been driving it since the problem developed. I'd like to drive it home, I can trailer/dolly it home if I have to... it's about an hour and a half drive from my place to the car but for the right price I'd be willing to go the distance.
Problem is the engine ticks starting around 2500rpm. The owner said it developed this problem and he parked it. He was led to believe its a rocker arm, but he hasn't investigated it himself.
I figured that it could also be a rod bearing or wrist pin, but does anyone else have an idea of what it could be? Are there any other symptoms of a thrown rod bearing or wrist pin I could look for? Has anyone ever attempted to replace a rod bearing or a wrist pin with the engine in the car?
sticky lifter or valve?
Open to ideas. I plan on running it, if I can't figure it out I'd pull the valve cover. I'm not an m20 guy so this stuff is all over my head.
Thanks in advance. Cross posting here and on BFC
